Need help with window problem...
Old Nov 4, 2008 | 12:24 PM
TTandTR3's Avatar
New Member
Default Need help with window problem...
The windows don't operate with the interior switches. They drop an inch when the door is opened and go up and down using the key in the door lock.
This doesn't seem to be covered in the FAQ and search indicated similar problem went away on its own.
Any ideas on a reset proceedure? Just wait a few days to see if it clears up? Or is it a bad switch?
Thanks.
Old Nov 4, 2008 | 12:38 PM
TTinCT's Avatar
Rest In Peace
Default you can try rebooting the car.....>>>
disconnect the negative battery terminal for a few minutes and reconnect. Make sure you have your radio SAFE code....
Old Nov 4, 2008 | 12:56 PM
TTandTR3's Avatar
New Member
Thanks, I'll give it a try.
Old Nov 4, 2008 | 02:15 PM
MarTT's Avatar
Default Remember, you'll have to do the reset procedure when you reconnect your battery:
From the owner's manual:
Power Window Convenience Feature Reset
1. Close the window completely by lifting the power window switch and holding.
2. Release the switch and then lift it again for a second.
The convenience feature is now activated.
Old Nov 4, 2008 | 03:10 PM
TTandTR3's Avatar
New Member
Thanks.
TT01Q
Dec 22, 2012 05:55 PM
olde_fortran
Jun 8, 2009 03:44 PM
Badd TT Bone
Mar 3, 2005 05:46 AM
CarmG993
Apr 29, 2004 01:21 PM
NeverEnough
Oct 22, 2003 01:07 PM
