bypassing radio wiring to emergency brake for using dvd while driving
Old Nov 5, 2008 | 11:42 AM
ed suarez's Avatar
New Member
Default bypassing radio wiring to emergency brake for using dvd while driving
My JVC that I installed requires that I connect a wire to the parking brake to use the dvd. How do I bypass the parking brake connection? It not only will be a hassle, but I would like that someone in the passenger seat can view the dvd screen while I am driving.
Old Nov 5, 2008 | 11:51 AM
DumpTTruck's Avatar
Default If you bypass at the handle won't you lose the warning light?
I'd just run the JVC wire to either 12v or ground which ever its' looking for.
Old Nov 5, 2008 | 11:53 AM
Mbaron's Avatar
He doesn't want to find that wire, wants to trick the headunit to think that the ebrake is always on
Old Nov 5, 2008 | 12:07 PM
adminisTerTurbo's Avatar
Default couldn't you just introduce 12v to the JVC wire?
from the dashlights or something...
Old Nov 5, 2008 | 12:08 PM
bwahaha, i should have read your post first...
Old Nov 5, 2008 | 12:21 PM
AxeYrCat's Avatar
Member
Default I had a toggle switch on mine that I had to flip... It was sort of a process:
Flip switch, depress brake pedal, flip switch again, release brake.
Dunno exactly what that voodoo was, but it worked.
Old Nov 5, 2008 | 06:17 PM
ed suarez's Avatar
New Member
Default Re: I had a toggle switch on mine that I had to flip... It was sort of a process:
I figured it out. It was very simple, just had to ground the wire. Now my next problem is I cannot find a switched power lead. All the power leads are always on, not switched by the ignition. Anyone know which would be a switched lead I could use. I don't want the radio to have to be manually turned off.
Thanks,
MoInEd
Q7 MKII Discussion
Nov 26, 2018 01:58 PM
DUTCH VanAtlanta
Q7 MK 1 Discussion
14
Apr 9, 2016 01:00 PM
VOoDOoGTX
Mar 5, 2007 07:25 PM
mdiscman
Jan 27, 2002 08:15 PM
