2 more issues with my car!!! What the.....
Old Feb 12, 2004 | 11:13 AM
lauk0dg's Avatar
Default 2 more issues with my car!!! What the.....
First Issue: Car would not lock with remote or key. Car would not even do anything when I hit the lock button. But funny thing is, when I shut down the car while I was inside the car, it would lock. Great. Also when I take out the key, the tone still sounds as if my key is still in there.
Second Issue: Car emit a loud clunk noise and a slight jerk on the wheel while braking. This doesn't happen all the time....it just happens maybe 5 times out of a day of driving that lasted 40 minutes. Now the thing is I don't know if it's the brakes themselves or just the motion of slowing down that caused something to hit something in the suspension, tie rods, etc..
Dealership's response to first issue: Vaccum pump and card module failure. It got flooded with water. They said they found 2 leaks: first leak from the right rear passenger side light assembly, and second leak from the cable leading out to the XM antenna on the trunk. They said the 2nd one was unlikely and I think the same, because that water should drain out like if it's rain water.
Dealership still diagnosing the 2nd issue. While I stopped by to drop off all my keys so they can reprogram the locks, their tech was test driving my car in the lot with a mic wired up to record the noise. While I was there he at least went back and forth 20 times accelerating and braking hard. I know this is regular procedure to try to mimic it, but it just hurt to watch. I guess good thing is they heard the noise, not the "Cannot reproduce" excuse.
Kudos to Laurel Audi and Jim.
Old Feb 12, 2004 | 04:54 PM
markbradford's Avatar
Rest In Peace
Who did the XM install?
Old Feb 12, 2004 | 05:46 PM
The_Real_Jeff_Gannon's Avatar
New Member
laurel rocks
Old Feb 12, 2004 | 08:18 PM
FBAnder's Avatar
indeed
Old Feb 13, 2004 | 06:49 AM
lauk0dg's Avatar
Best Buy @ Downers Grove. Been installed for over a yr already.
Old Feb 13, 2004 | 06:51 AM
lauk0dg's Avatar
Default UPDATE: So they found where that clunking noise came from......
It's a front passenger side brake pad coming loose. Ouch.
So they put new pads on the front (and I surely hope they put them on tight).
Yup Laurel rocks. Especially Jim Finch.
Old Feb 13, 2004 | 08:13 AM
Tom M's Avatar
New Member
Default Laurel Service is the Best.
Luckely when I purchased my 2000 2.7 I did not go with Rock bottom Price. Laurel was by far the closest to my house so I thought the extra 5 or 6 Hundred dollars in the long Run would be worth it. I did not realize at the time how much good service versus Bad service means. I do Now . Jim and Ed and Joe are Great .
Tom
Old Feb 13, 2004 | 11:04 AM
Shameless in Chicago's Avatar
YMMV
 Michael S. Palmer
Ty Ty
Q7 MKII Discussion
18
Mar 5, 2018 05:19 PM
Tman007
A7
10
Oct 1, 2015 07:25 PM
drvai
Jul 17, 2014 07:05 PM
bagxlee
Dec 7, 2009 05:19 AM
XCCESS
17
May 23, 2007 06:20 PM
