Anyone have a breakdown sheet, or just insturctions for taking out the grille and middle bottom...
Old Apr 10, 2003 | 08:01 AM
Pholden's Avatar
Default Anyone have a breakdown sheet, or just insturctions for taking out the grille and middle bottom...
grille? I am going to try to black tape on the silver part to see if i like it enough to buy the black pack grille from vagparts.com. Thanks in advance.
Old Apr 10, 2003 | 08:24 AM
GreatLakeAvant's Avatar
Junior Member
Default You may want to rely on the photos provided, already.
I wouldn't go through the removal just to put some electrical tape on your current grille. Getting the lower grille out is a little tough, and I would only suggest doing it when you get the new grille [once is enough!]. Especially, if you end up breaking off a retaining clip in the process.
Pop the hood and you will see that the upper grille has several retaining clips holding it in place. The lateral clips are the most important [and strong], and that is where I started.
The lower grille is more difficult to remove. You definitely want to work from above, once you lift the hood. Someone once posted that all you need to do is "pull on it." I think you will have better success [i.e., not break it!] if you push down on the black, plastic retaining tabs [2, I think] that protrude through the metal supports, behind the grille, while pulling on the front, slowly. You can see the tabs when looking down behind the bumper, from above. Be very careful not to damage the fins on the intercooler [cover with a thick towel].
Both grilles will snap back into place with gentle pressure applied evenly across their faces.
Check out my picture poster to see what the OEM grille looks like when installed [though it isn't on a black car].
maximusx360
Want To Buy - Archive (NO NEW POSTS HERE)
Apr 8, 2016 05:33 PM
JohnHugill
Sep 17, 2015 05:01 AM
Wza
A6 (C7 Platform) Discussion
Sep 10, 2015 11:03 AM
giuseppepat
Sep 2, 2015 02:47 AM
