tech question on the gas pedal and responsiveness
Old Aug 31, 2003 | 02:13 PM
FoKai's Avatar
Default tech question on the gas pedal and responsiveness
whenever i step on the gas pedal, it doesn't respond as it used to unless i push it halfway to the floor. and when it does respond, it doesn't accelerate as quick is as responsive as it used to be. i turned it in to my local audihaus and they checked it out; unfortunately the results were in german. they ended up ordering a gas pedal set (i'm assuming with all the other stuff that goes with it) and they fixed it, but its back to its sluggish mode. any insight is appreciated; the vag results were in german. all i understood was "halb drucken gaspedal..." something. thanks.
Old Aug 31, 2003 | 02:15 PM
yourk's Avatar
AudiWorld Expert
tiptronic? if so.. there should be a small lag in throttle response.. just the way the car was made.
Old Aug 31, 2003 | 02:16 PM
lawong's Avatar
search for instructions on how to do a Throttle Body Adaption...
Old Aug 31, 2003 | 02:29 PM
FoKai's Avatar
thanks but no, its different than the 1 second lag.
Old Aug 31, 2003 | 02:34 PM
FoKai's Avatar
thanks, thinking back, my audihaus did disconnect my battery when they replaced my cps. hmm..
Old Aug 31, 2003 | 03:02 PM
lawong's Avatar
Default it may/may not help. 1.8T? try replacing your BPV. Also, there are a few cases of bad throttle
bodies. If its a easily reproducible problem, you can always bring to dealership and show them...
Old Aug 31, 2003 | 03:19 PM
FoKai's Avatar
Default i just did a search on the TBA; i'll try it but don't have vag.
yeah, 1.8t tip. i was thinking of replacing the oem bpv and was thinking of getting the evos. what do you think? also, how can i check for bad throttle bodies? the wierd thing is, in the morning when i fire up my car and drive, it responds really well.
Old Aug 31, 2003 | 03:32 PM
lawong's Avatar
Default here's a link for the TBA, no vag needed..
I have my own personal opinions about BPVs. I'd go with Forge or Bailey. I'm sure the others work just as great.
As for EVO, are you referring to the EVO intake? We've had debates in the forum regard those. I am not convinced the stock air intake to be restrictive at all. Others will disagree and give their own opinion saying that EVO will improve performance. Oh well... draw your own conclusions about that..<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/266098.phtml">https://forums.audiworld.com/a4gen2/msgs/266098.phtml</a</li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 1, 2003 | 08:48 PM
FoKai's Avatar
did the TBA; didn't hear no clicks but responsiveness seems a bit better
carl viking
40
Jul 12, 2024 02:45 PM
dougpaper
A6 (C7 Platform) Discussion
10
Apr 23, 2020 12:58 PM
N'Syncro
33
Feb 16, 2020 03:12 PM
audijim113
Sep 3, 2015 01:22 PM
zjw8407
Sep 2, 2015 05:20 PM
