Anbody have a squeeky noise apparently coming from the sunroof???
Old Sep 1, 2003 | 06:09 AM
Black4.2S4Vin's Avatar
Default Anbody have a squeeky noise apparently coming from the sunroof???
When i tilt the sunroof up the squeek is elimnated when i go over road bumps or such. when i put it back down it makes the horrendous noise.
The car is tight as hell but that noise can drive me crazy.
I think its the sunroof because when i lower the tilt it makes a squeeky sort of noise when gettign totally aligned flat.
Old Sep 1, 2003 | 06:24 AM
Peppe1.8T's Avatar
Default YES! I am so annoyed by it also.....
took it to dealer about a year ago and it went away and now it has been back for a while. Like you said when sunroof is tilted it does not make the horrible noise. That noise and my brakes make a ringing noise when I go over bumps.
Old Sep 1, 2003 | 06:27 AM
IBD SV's Avatar
Junior Member
Default The dealer re-greases the sunroof (m)
on my 02 A4 they said it would continue to happen and I could keep bringing it in or take silicon spray and spray the rubber around the sunroof. I did this and it solved the problem for me.
Old Sep 1, 2003 | 06:50 AM
coolnesh's Avatar
Default Re: Anbody have a squeeky noise apparently coming from the sunroof???
i get more like a rattle ....
taken it 3 times to the dealer and twice they said they could not replicate the problem... and one they fixed it but the noise comes back now and then ....
damn annoying ... i have to crank up the volume not to get pissed off.
Old Sep 1, 2003 | 06:52 AM
coolnesh's Avatar
Default Re: The dealer re-greases the sunroof (m)
can u tell us which spray u used and maybe a small write up on how u did it ?
thanks
Old Sep 1, 2003 | 12:43 PM
Man Of Many Parts's Avatar
Junior Member
silicone grease
Old Sep 1, 2003 | 02:07 PM
<center><img src="http://pictureposter.audiworld.com/52520/picture_028.jpg"></center><p>ok cool i'll regrease it or whatever cuz it drives me nuts!!
Old Sep 1, 2003 | 02:20 PM
needforsleep's Avatar
Unfortunately, again, I must say Yes. I have this problem too. Going to re-grease it myself.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 1, 2003 | 06:46 PM
IBD SV's Avatar
Junior Member
Default Exactly as said below (m)
Use silicone grease. I got it in a can like wd-40. To grease the sunroof gasket you just soak the entire rubber weatherstripping around the sunroof in silicone grease. You do this by spraying the silicone from the can all over the gasket. In order to do this you will need to open the sunroof. First I popped up the sunroof by pushing the dial up, then I coated all the weather stripping I could. Then I slid the sunroof open by turning the dial 3/4 of the way around and then managed to spray the rest of the weather stripping. It does not matter which method you use just as long as you coat all of the weather stripping with the silicone.
mkiv808
Audi A3 / S3 / RS 3
13
Aug 11, 2018 05:01 AM
Captain Rossness
Audi A3 / S3 / RS 3 MKII
26
Sep 24, 2015 05:34 AM
ILTRAVELER
Q5/SQ5 MKI (8R) Discussion
Sep 6, 2015 08:56 AM
audijim113
Sep 3, 2015 01:22 PM
stormchaser1967
Sep 2, 2015 12:47 PM
