No display - Solid Red Stereo
Old Mar 12, 2005 | 10:55 AM
scottmcc8audia4's Avatar
New Member
Default No display - Solid Red Stereo
Please help, i had to remove my stereo and when i put it back in i only get a solid red light. no safe message or place to put my security code in. could someone please help. i do not want to go to the dealer and pay an arm and a leg for this PLEASE!
Old Mar 12, 2005 | 11:02 AM
PlainRuss's Avatar
Member
Pull the radio fuse out, wait 10 seconds, put it back in.
Old Mar 12, 2005 | 11:18 AM
sheepfu's Avatar
New Member
Its true, works every time. I told the Audi Dealer it happened to me and they replaced the radio
Old Mar 12, 2005 | 12:07 PM
A4wheelin's Avatar
Default Same here.
Once pulling the fuse didn't work though. Dealer said that there is a fuse in the back of the radio that blew.
Old Mar 14, 2005 | 11:15 AM
New Member
Default Re: Pull the radio fuse out, wait 10 seconds, put it back in.
I tried pulling the fuse out of the back of the stereo out and waited 10 secs and no luck. do i need to pull the fuse out of the fuse panel for 10secs. what fuse it is?
Old Mar 14, 2005 | 11:18 AM
PlainRuss's Avatar
Member
Default Pull the one out of the dash.
If that doesn't do it, you probably need a new head unit.
Old Mar 14, 2005 | 11:49 AM
New Member
Default Re: Pull the one out of the dash.
Ok, i pulled the one out of the dash with many different scenarios (radio off, car off, radio on, car on, etc) and no luck.
when i put the fuse back in the radio display gets bright red and then back to normal color red but still nothing is displayed. just a blank red screen.
i wonder if my radio is broken. i checked all the fuses and none are bad.
Old Mar 14, 2005 | 11:55 AM
PlainRuss's Avatar
Member
Default Yeah, chances are it is.
I have had a couple that wouldn't work and ended up replacing the radio.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 14, 2005 | 05:31 PM
New Member
Default replacing the radio
when you replaced the radio did you have to get a new amp? i have thought about replacing the radio but i am afraid that i will not be able to use all the speakers and that i may have to get a new amp. let me know what needs to be done in order to replace the radio. thank you,
scott
Old Mar 14, 2005 | 07:29 PM
PlainRuss's Avatar
Member
Default You'll have to do some research if you're going aftermarket.
I am a dealer tech, so the factory stuff is just plug and play.
random512
A6 (C7 Platform) Discussion
27
Apr 15, 2019 10:45 AM
T1no33
Audi A3 / S3 / RS 3 MKII
14
Feb 9, 2019 01:55 PM
Kerry G
May 18, 2018 06:12 AM
lbennett12
Sep 27, 2015 09:18 AM
Bruce B
Q5/SQ5 MKI (8R) Discussion
Sep 25, 2015 12:11 AM
