Hello again, one of my tires sounds like a waterhog snoring after I rotated my tires. Backwards??
I'm guessing one of them is unidirectional or all of them?
how did you guys rotate your tires.
SOrry, I'm away from home, and don't have my manual with me.
Thanks
Also, it's usually not a good idea to run with one different tire. The Pirelli may have a different wear rating, different tread pattern, and different handling characteristics. It can throw the performance off on your car. The design of the one Pirelli may be different enough to actually fight against the other tires (not a good thing).
If you have to replace one tire, it's better to replace two (if replacing one front tire, then replace both front tires).
Hmm.. do you know if the stock tires 17" alloys are directional? The stock Pirellis that is. year 2003
Thanks again for your help
