sp now that I did som VAG-Log runs on Ocean parkway..
What kind of runs did you do?
I usually do two sets of logs... FATS logs using blocks 003, 005, 011 From these blocks you can get a good idea of IAT's, Coolant temps, Mass air flow and throttle plate position (indicator of throttle cut) as well as the obvious FATS times. The FATS times, IMHO, are not very accurate for comparison to other vehicles...save this for the dyno; rather it is a great comparative for modifications to your own car.
I also log 115. This will give you Specified versus Actual boost. An accurate indicator of the boost levels as well as the ecu's response to the request for boost.
