Cool find. I guess it will not clear a lot of the lowered cars. 6" clearance.
All you need is a 120psi compressor. Imagine if you can get 4 of them. that would make an instant lift.
Air operated (120psi working pressure)
Control valve keeps jack inflated when air supply is disconnected
Safety valve prevents overloading
Tested in accordance with industry safety standards
Wide flat steel base for extra stability
Two handles for easy positioning
Powder coated finish
1.8 Ton capacity (3,600lbs/1,632kg)
Minimum height 6.5"
Maximum height 17.25"
Weight: 41 lbs
Dimensions 17.8" x 11.1" x 6.8"
2.2 Ton capacity (4,400lbs/1,995kg)
Minimum height 5.75"
Maximum height 12"
* Weight: 51 lbs
Dimensions 19" x 12.9" x 6.4"
90psi is all you need to lift one side of the car...it's heavy & huge, but that's what garages are for!
