Vehicle exit outside courtesy lights ? can Vag shorten to say 15seconds ?..Codes ?? TIA
Go to the menu & select:
vehicle settings --> courtesy lights --> outside lighting
Also allows you to set footwell lighting and duration & whether low-beam xenons come on when you unlock it at night.
S4 may be the same way...?
BTW, did you know that you could use the VAG to put the DRL into the menu for the Touareg? That's the first thing I did... turned those annoying PITA things off!!
-JPC
