S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Questions on Milltek DPs and Res. Exhaust Install
Old Mar 8, 2005 | 03:01 AM
S42U's Avatar
New Member
Default Questions on Milltek DPs and Res. Exhaust Install
Having DPs and Res. Exhaust installed this Friday by KMD Tuning here in NJ. I am looking for feedback from AWers as to issues/concerns etc I should look out for to ensure that the install is done right.
Two come to mind: first, the fuel evap. line. I know pictures were previously posted of what to look out for, but I can't seem to locate that post (and yes, I did search). If anyone can point me to the post or send me pictures, much 'preciated.
Next, tip alignment. Hopefully KMD has enough experience doing the install that this won't be an issue, but we'll have to wait and see.
Any other things I should be on look out for?
Old Mar 8, 2005 | 05:31 AM
MachtigAvant (v3.0)'s Avatar
Elder Member
Default KMD should knock this out in no time. It's not that difficult actually.
Make sure that they remember to invert the hangers for the dp's. I'm sure they'll figure it out.
As for the alignment, best tip I can give you is to remind them that they can twist the rear sections (with the cans) in order to raise or lower the section. THEN, put the tip on so it's centered and straight.
As for the evap line, it was not an issue with me. Just make sure that there is some type of heat shielding wrap on it.
Old Mar 8, 2005 | 05:37 AM
detailersdomain's Avatar
Former Vendor
Default You shouldn't worry about it too much...they will get it right
They've done quite a few of them already...are you doing the DP's too?
Old Mar 8, 2005 | 05:39 AM
HarnessedLunacy's Avatar
Default here's a link to a thread about the fuel evap line. . .
I would mention it to them before they do the install just to make sure that they are taking it into consideration. . .<ul><li><a href="https://forums.audiworld.com/s4b6/msgs/134906.phtml">https://forums.audiworld.com/s4b6/msgs/134906.phtml</a</li></ul>
Old Mar 8, 2005 | 05:50 AM
JDBlueAudiS4's Avatar
Its a 3 hour install if you have done it before....
Old Mar 8, 2005 | 04:33 PM
S42U's Avatar
New Member
Default Thanks all who replied..
Looking forward to the new pipes!
Old Mar 8, 2005 | 07:26 PM
too good to be true's Avatar
Junior Member
But you will still get charged by the book time 5 hours.
rsixxer23
Jan 6, 2016 03:25 AM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
Sep 3, 2015 11:45 AM
giuseppepat
Sep 2, 2015 02:47 AM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
Sep 1, 2015 11:57 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
Sep 1, 2015 09:16 AM
