S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
RS4 accelerator pedal cover, pain in the @$$
Old Feb 10, 2006 | 12:56 PM
SharkyS4's Avatar
Junior Member
Default RS4 accelerator pedal cover, pain in the @$$
Does anyone have tips on how to install the RS4 pedal covers? particularly the accelerator one? I managed to get the clutch and brake on, but the accel is being quite seditious... I tried a bit of lube, (haha, he said lube!) silicone grease, it helped with the clutch pedal cover, but just can't seem to get that accel cover on....
Any help would be greatly appreciated...
-SharkyS4
P.S. Also, what is up with the plastic/composite pedals arms for the clutch and accelerator? It' s kinda scary...and cheap, no?
Old Feb 10, 2006 | 01:03 PM
miketaylor01's Avatar
Member
Default just pure force is the way to go.. took me about 30 min to get all 3 on and...
my hands hurt like hell when I was done, but I was able to get them all seated without lube. I only used force and a screwdriver to pry some of the tougher edges around the pedals. The accelerator was a pain though if I remember correctly. Clutch was the worst for me though. Sorry I didnt use any tricks except a flat tip screwdriver
Old Feb 10, 2006 | 02:20 PM
123Thumperer®'s Avatar
Elder Member
Default why not wrap in a cloth, then put some vice grips on one side, and squeeze with pliers...
on the other. that should snap it on.
Old Feb 10, 2006 | 03:09 PM
V8's Avatar
V8
Junior Member
2nd, brute force and a flat tip screwdriver... the acclerator cover was the hardest for me as well.
Old Feb 10, 2006 | 10:41 PM
Cruz's Avatar
New Member
Default I take it they are made of a hard semi-rigid rubber...
right? If so soak the pedal cover in hot water for a couple of minutes to make it more pliable. That's what I've done before on previous OEM pedal swaps & it's worked like a charm. Hope this helps.
N'Syncro
33
Feb 16, 2020 03:12 PM
Ariaze
Sep 3, 2019 08:06 PM
vwleadfoot
Audi Original "S" Cars
Dec 24, 2015 06:07 AM
scottmn4
A4 (B8 Platform) Discussion
Sep 21, 2015 05:33 AM
RTnDL
Sep 7, 2015 11:17 AM
