Help with bleeding!
Old Dec 20, 2009 | 02:26 PM
Turbowins's Avatar
Default Help with bleeding!
I just replaced the abs pump/module whole assembly on my 2001.5 s4 6mt. I am trying to find out the exact bleeding procedure to bleed the system and what NOT to do. I know so far you have to start at the passenger rear then driver rear then passenger fron then driver front but do I cycle my abs before i bleed or do I bleed first and cycle the abs last? Does the car need to be running? Does the whole car need to be in the air? Some help would be greatly appreciated.
Old Dec 21, 2009 | 05:29 PM
Turbowins's Avatar
Default Also
When changing out the abs module does it need to be re-coded before you cycle it? If so are the codes all the same for bosch 5.0's or is it vehicle specific?
Old Dec 22, 2009 | 01:16 PM
Calif_Kid's Avatar
Default Re: brake bleeding
Here's a link with some info about bleeding brakes including the ABS unit: http://forums.quattroworld.com/s4/msgs/29525.phtml. Since the ABS unit is completely dry, it seems reasonable to maybe first bleed it to the left front first to get it full of fluid, and then to go thru the whole normal procedure (bleeding all four corners and then the ABS to the left front). If you're using a manual method (instead of a power bleeder), then the articles mention to make sure to not push the brake pedal all the way to the floor or you could damage some of the seals. You can always try searches on AudiWorld, QuattroWorld, and Audizine as there may be more info. Personally, I've used a power bleeder, but haven't tried bleeding the ABS unit, but will be giving that a try soon. - Jim
Old Dec 22, 2009 | 01:27 PM
Calif_Kid's Avatar
Default Info on ABS bleeding
Here is some info from the Ross-Tech page (scroll down to the Audi section of the page): http://www.ross-tech.com/vag-com/cars/absbleeding.html. - Jim
gakor
Sep 27, 2015 02:10 PM
G_claudz
Sep 15, 2015 10:47 AM
suavetony
9
Sep 13, 2015 05:17 PM
RTnDL
Sep 7, 2015 11:17 AM
James R.
Feb 22, 2001 04:45 PM
