Can anyone remember the company that sells the timing....
Old Jan 1, 2010 | 09:11 PM
q2quest's Avatar
Default Can anyone remember the company that sells the timing....
belt / water pump kit and provides the install DVD with it? Thanks
Old Jan 2, 2010 | 02:54 AM
Tippin's Avatar
JHM
Old Jan 2, 2010 | 05:28 AM
jukesandz's Avatar
Default Here's a link
http://www.jhmotorsports.com/shop/ca...products_id=76
and the DVD is very good. As a note though, it starts with the front clip removed already, so just be sure you can get down to that point.
Old Jan 2, 2010 | 09:56 AM
q2quest's Avatar
Thanks guys. That is kind of weak about the front clip being off already in the video, though.
Old Jan 2, 2010 | 11:42 PM
Indyxtype's Avatar
Highly recommend. It's a truly a walkthrough. Load up on some additional info and you'll be golden. Here are some links to stuff that I found useful including getting to the service (removed front clip) position. Only thing I personally disagree with is would recomend is getting the cam lock bar rather than the mark and move method he uses.
guide to a 2.8 which is essentially the same motor, just without the turbos - https://www.audiworld.com/forums/sho...oto=nextoldest
Phenominal guide to get into the service position.
http://www.vaglinks.com/Docs/Audi/B5...stallation.pdf
A good supliment to the guide above for getting into service position.
http://www.awe-tuning.com/pages/faq/...ain.cfm?FAQ=43
The hardest part of the whole job is getting the damn bumper cover off. After that it's smooth sailing as long as you keep track of what screws and parts go where when you take them out.
Old Jan 3, 2010 | 01:13 AM
q2quest's Avatar
Wow, thank you so much! That really helps a lot. I'm thinking about picking up a 2002 4.2 (A6) and I'm going to attempt my own timing belt change when the time comes.
Mesa512
S4 (B8 Platform) Discussion
20
Jul 7, 2018 11:23 AM
WillSav
Mar 19, 2016 04:44 PM
X-540i$A6
Oct 22, 2015 11:35 AM
blackjulia
Sep 27, 2015 09:37 AM
Service365
New Member Welcome Area
Sep 26, 2015 10:12 PM
