new to audi!
Old Mar 5, 2011 | 09:33 AM
audibmc's Avatar
Default new to audi!
i purchased an 01 tt quattro 2 nights ago with 75thousand. already know the whole timing belt kit needs done. but im having a few issues. yesterday i was driving all was well and about an hour into driving it the center message display just started to fade out. also i noticed when i started my car this morning that the temp guage was already up to the first line, and the center message display read OK SERVICE! then went directly out. i already found out that theres an issue with the fuel gauge due to the fact that it ran out on me even though it read a quarter tank with the gas light on. i was just looking for some guidance with the instrument panel. i am also changing the haldex filter and oil so i got some of the basics down just worried about these other stupid issues. also anyone ever have a problem with the black cup that screws into the valve cover leaking?
any help is greatly appreciated
thank you,
brandon
Old Mar 6, 2011 | 03:48 PM
AudiMick's Avatar
The clusters have a "history" on the TT, several recalls since expired.
Three problems: Center info display fails or loses pixels, fuel gauge error, temp gauge error.
In addition the fuel sender(s) in the tank get corroded (ethanol in the gas?) and throw the readings off.
Check the fuel gauge against the miles to empty. For example if it says 50 miles to empty and the gauge says 1/2 full it's probably the gauge.
If they agree it is probably the sender.
There are several companies that can rebuild your cluster. Module-master is one.They have instructions on how to remove your cluster. Your cluster has the immobilizer code for your TT so it is better to repair than to replace. Replacing the cluster would mean a trip to the dealer.
If you intend to hang on to your TT, buy a VAG.com from Ross-tech (or borrow one). You can test all the gauges using VAG.com.
Having a bad temperature gauge is not a great idea as you could overheat the motor without knowing it.
The fuel sender(s) can be cleaned and re-installed. About 2 hours work and $20 of gasket seals.
Since you are apparently having multiple cluster problems that's where I would check first.
And FYI on every Audi I have ever owned running temp is 12 o'clock on the gauge. If it isn't gauge is off, temperature sensor or thermostat is bad.
Old Mar 6, 2011 | 08:19 PM
audibmc's Avatar
Thank you AudiMick!
Also upon starting my car this morning it says OK overtop of SERVICE on the center display. Everything seems fine and well will vag com tell me what that is about? And which model of it do i look into buying, sorry for sounding like a total idiot im just totally new to these and didnt do that much research before buying it other than the haldex issue, timing issue, and a little of the cluster.
Old Mar 7, 2011 | 06:10 AM
AudiMick's Avatar
Originally Posted by audibmc
Thank you AudiMick!
The warning does not indicate a problem with the car.
SERVICE is a reminder for you to drop your wallet and car off at the Audi Dealer. It's a reminder by mileage or time to have routine maintenance done. You can reset it by pulling on the R/H stalk in the cluster and turning it (instructions in the owners manual). You can also use VAG.com to reset and change the parameters of the reminder.
My TT didn't come with a manual so I bought one on E-bay for $20. It's actually worth having and reading, some of the cluster displays are kind of strange.
Old Mar 7, 2011 | 06:15 AM
audibmc's Avatar
thats what i figured i had a bmw and it would randomly say hey jerkoff service and it was just like an oil dummy light, just came on as per the manufacturer. once again you have been great help sir.
Old Mar 7, 2011 | 08:54 AM
AudiMick's Avatar
No problem, enjoy your new car!
kopee1
Oct 6, 2011 12:25 PM
Audi_tt_2000
Jun 17, 2010 07:54 AM
sgfatc
18
Aug 5, 2005 05:55 PM
nansaidh
Jan 25, 2002 02:07 PM
panacea
May 28, 2001 01:33 PM
