one touch & quick drop window problem
Old Apr 27, 2011 | 04:15 AM
snickers's Avatar
Default one touch & quick drop window problem
My '01 TT has developed a problem with the driver side window. The feature where the window drops upon opening the door doesn't work now and at the same time the one touch up and down stopped working. The window will still operate up and down if I hold the button. Any ideas?
Old Apr 27, 2011 | 06:54 AM
bmwlocoTTtoo's Avatar
Does it still work with the switch?
Sounds like a window regulator.
You can take it to Audi and have the codes read, or you can buy a cable and hook it up to a laptop or handheld. Either would probably work, and tell you where the problem lies.
Good luck!
Old Apr 28, 2011 | 03:55 AM
snickers's Avatar
The problem was solved by disconnecting the battery...everything was reset.
Thanks for your input.
ay6
Nov 23, 2015 08:12 PM
sbrar96
Q7 MK 1 Discussion
May 21, 2014 04:18 PM
sims159914
Jun 22, 2007 12:43 PM
Kugs10
Feb 26, 2001 06:18 AM
ecook
Jun 23, 1999 06:09 PM
