97 cabriolet running rough
Old Aug 13, 2011 | 06:05 PM
Old_Mil's Avatar
Default 97 cabriolet running rough
Does it at idle and at speed...quite a bit of power loss involved and running quite rough....check engine
Iight is on steady, flashed for a bit then back to steady.
"I have a very bad feeling about this."
- Han Solo
Old Aug 14, 2011 | 02:12 AM
maineman's Avatar
Default When was the last time
you did a tune up?
Checked for vacuum leaks?
Checked or Cleaned your Idle control valve?
Good luck
Old Aug 14, 2011 | 06:42 AM
grillage's Avatar
check the codes!
http://12v.org/maintenance/dtc.php
Old Aug 15, 2011 | 10:41 AM
Loudgoldwing's Avatar
Old Mil,
Are you in WI, as your name would suggest? If so, let me know. I might be able to help.
Brozee
19
May 2, 2012 05:34 PM
10vCoupe
Inline-5 Discussion
Jan 7, 2009 06:29 PM
peterklos
12v V6 Discussion
Dec 12, 2007 12:02 PM
jonty
Dec 29, 2003 11:56 PM
Turbo2
Jun 6, 2002 04:44 PM
