Suspension Air Leak Troubleshooting
First post here after buying my wife a 2005 A8 about 2 months ago. The yellow and green suspension lights lit up yesterday and the front of the car lowered to the bottom stops. I ran a Vag-Com scan and pulled 3 codes on the front suspension:
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 25166 444 84618
VCID: 28551379E263
3 Faults Found:
01400 - Suspension Level Control
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 4
Reset counter: 79
Mileage: 155988 km
Time Indication: 0
Date: 2011.09.08
Time: 17:28:51
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 8
Reset counter: 119
Mileage: 155995 km
Time Indication: 0
Date: 2011.09.08
Time: 17:38:11
01583 - Leak in System Detected
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 79
Mileage: 156017 km
Time Indication: 0
Date: 2011.09.08
Time: 20:35:33
The 10 amp and 40 amp fuses are not blown.
My question is, how do you you go about troubleshooting the air suspension? Is there a way to pressurize the system to look for leaks? Would Vag-Com have given me a different fault code if the struts were leaking? Am I safe to assume that since both struts lowered the same amount that it's not the strut but a leak elsewhere? It seems a lot of folks end up replacing the compressor but there's got to be a way to test for leaks first, right?
I've searched the archives on this board, the Vag-Com website and looked on Elsa for guidance but nothing. I do not have a copy of the Bentley manual yet but obviously see a need for one now.
Thanks in advance for any guidance!
lift the car with a floor jack one side at a time and with the engine running spray around the air spring and look for bubbles.
much easier on the Allroad as the design is different.
you can check the pressure with the vag tool.
Mine had exactly the same issues as you've mentioned, including the VAG codes
Compressor dies as a result of not being able to continually pump air through the system.
In my case, the front right strut had failed. The compressor then died, followed quickly by the relay. Took Audi three attempts to find the culprit.
You're question about the whole front dropping meaning a separate issue to struts could be true, but it's likely that the compressor can longer pump up the car and is actually the end result. (Remember that the rear has an air reserve so stays lifted.)
My 2c opinion - strut leak or leak feeding a strut, comp dead, relay fried. I HOPE I'M WRONG THOUGH! Good luck.
Thanks for the quick replies!
I'll plan on jumping the compressor tomorrow to see if it's still alive. I've already got the wheel and liner off so everything is exposed.
S4Master1,
Where should I spray the struts specifically? I'm not used to these integrated set-ups. The only other self-leveling suspensions I've worked on were the old BMW E32's that had the seperate resevoirs or bellows.
AusA8,
Your experience is my fear.....or reality. The sequence of fault codes appears to lead me down that path.
Thanks!
Ben
At least I know where all the air lines run and can hopefully trace down the leak, if it's not at the compressor, once I verify the compressor works and can pressurize the system.
I pulled the relay yesterday and took it apart and it looks new. Kind of confusing markings on it though. Relay number is 100 951 0001 "Meyhle Germany" and then a paper sticker that says "Made in China".
I did a quick Google search and it resulted in no local U.S. suppliers so I'll probably just cough up the $27 to my dealer for the $5 relay just to be sure if I replace the compressor.
Thanks!
I'll keep them in mind for comparison shopping though.
Thanks!
