Voice activation security is locked?
Old Oct 10, 2011 | 06:30 AM
ebloom2201's Avatar
Default Voice activation security is locked?
Each time I use my voice activation in my 2006 A8 is says it is locked. How do I get this unlocked? I do not remember adding any security code and already tried using the normal 1-2-3-4. Any help will be appreciated. Thank you, Evan.
Old Oct 10, 2011 | 06:32 AM
ebloom2201's Avatar
Originally Posted by ebloom2201
Each time I use my voice activation in my 2004 A8 is says it is locked. How do I get this unlocked? I do not remember adding any security code and already tried using the normal 1-2-3-4. Any help will be appreciated. Thank you, Evan.
Sorry...This is a 2004. Sorry.
Old Oct 10, 2011 | 07:45 AM
Brozee's Avatar
Try 0-0-0-0 or 1-1-1-1. May have to have it unlocked with vag-com. I've never heard of this before.
Old Oct 10, 2011 | 05:33 PM
05SilverA8's Avatar
Default Voice Module
If this is a new component in the car the Dealer has to unlock it.
Old Oct 11, 2011 | 06:48 AM
ebloom2201's Avatar
No, it is not a new component. I'm stumped as to how it used to work perfectly fine and now it does not. For any voice command it says that security is enabled. When I use the voice command of security to turn it off there are no codes that work. Plus I did not turn on the security.
ashwarsop
Q7 MK 1 Discussion
Feb 27, 2019 03:13 PM
hanilanzi
VAG-COM Discussion
Dec 6, 2011 05:01 PM
ebloom2201
Telematics Discussion
Oct 10, 2011 06:54 AM
akielb
Apr 9, 2007 03:46 PM
