VAG-COM Discussion
Trying to code a key... 46-Central Conv. reports "no response from controller"
Old Nov 23, 2011 | 08:54 PM
hanilanzi's Avatar
Default Trying to code a key... 46-Central Conv. reports "no response from controller"
is it just some years of cars where you can code a key with a VAG-COM or should it work on all, because when i try to access "46-Central Conv." through VAG-COM it says "no response from controller"
This happens on 2000 A8 and 2001 A8.
anyone?
Old Nov 24, 2011 | 08:50 AM
bearthebruce's Avatar
Audiworld Premium Sponsor
With a full and genuine Ross-Tech VCDS (VAG-COM) system, you should have full access to module 46. Care to share what you are using to try to do this?
-Bruce-
Ross-Tech, LLC
Old Nov 24, 2011 | 06:23 PM
hanilanzi's Avatar
i just purchased a new genuine HEX + CAN USB ($349) cable and donwloaded the latest software, plugged the cable in my car (tried both 2000 and 2001 A8's) and followed the instructions to access 46 (select, 46-Central Conv.) and here is where i get the error - No response from the controller.
I was able to read the DTC's do an SRI reset, adjust my xenons, played with adjusting the idle RPM, logged couple of things while running a car,... everything seems to be working, but for some reason i can't connect to 46.
Thank you
Old Nov 25, 2011 | 05:28 PM
hanilanzi's Avatar
seems like these forums here are a waste of time, since it's taking so long for anyone to even reply to anything, and in the mean while just by exploring and testing stuff with my new cable / software and my car i figure most of the stuff on my own.
just wanted to say i figured this one too! )
one of my audis honk didn't work when i locked the car and activated the alarm. well that is working now too... i love the binary system conversions )
Old Dec 6, 2011 | 05:01 PM
Theresias's Avatar
You can always email us directly, the response time that way is usually a lot faster than in a forum.
S4ptld
May 21, 2008 11:09 PM
summit25
May 13, 2008 03:12 PM
akielb
Apr 9, 2007 03:46 PM
Yan
Jun 24, 2002 07:16 PM
MyKey
Mar 20, 2002 05:30 AM
