Oil Pressure warning light in dash..what sensor?
Old Nov 6, 2011 | 04:03 PM
quattromano's Avatar
Default Oil Pressure warning light in dash..what sensor?
Fires it up? I know it isn't the 2 down by the oil filter. There has to be one some where on the block...anybody??
95 90 FWD w/AT.
Old Nov 7, 2011 | 05:22 AM
GuyllFyre's Avatar
If it's the V6, it's definitely one of the two sensors down behind the oil filter.
Old Nov 7, 2011 | 06:22 AM
Sorry no they are not. I pulled the wires on both & the Warning Light still comes on.
Have found out that 1 wire is for low pressure and one for high pressure but not warning
lite.
Somebody mentioned a 1 wire sensor between the AC Compressor & the Crank.
Old Nov 7, 2011 | 07:42 AM
GuyllFyre's Avatar
Guess your car is wired differently than mine.
On my car, the light in the dash is low pressure and comes on with the sensor that's on the Tee behind the oil filter.
I know this is true because I replaced the sensor with a dual sender/sensor so I could add an oil pressure gauge.
Old Nov 16, 2011 | 02:26 PM
duanevw's Avatar
I just installed my engine with new oil pump and I installed the new blue oil pressure switch because I had the oil light come on with it beeping. I still have the oil light when I slowly rev it to about 2300 rpm in neutral. So it must be the other oil switch just across from it on the same tee?? Am I right Gullfyre?? Thanks Duane
Old Nov 17, 2011 | 04:34 AM
GuyllFyre's Avatar
Here's your oil pressure switch/sender options:
http://www.germanautoparts.com/Audi/...ectrical/150/3
The senders are only $15 for the both of them, so not expensive, plus, be sure the tee is cleaned out.
If you are adding an OEM oil pressure gauge, you get the dual unit and replace the blue switch.
Of course, before going too insane, be sure you put a gauge on it and make sure your oil pressure is OK through the range.
Old Nov 19, 2011 | 03:08 PM
duanevw's Avatar
Fixed, it was the high pressure switch on the tee in front of the upper oil pan, I thought I would have to removed the compressor and lines all over again. Dad made a special wrench with torch and just good enough to get at it!! I swear €udi didn't think about sensor replacement and im sure it would be a $300.00 job for a 12.00 part if you didn't know no better. …Pretty Scarry
Old Dec 5, 2011 | 03:56 PM
THAT IS EXACTLY MY PROBLEM! When the oil is cold nada...but after it warms up bingo!
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 5, 2011 | 06:30 PM
duanevw's Avatar
I pm you on the sensor that's right on the front just left of the oil cooler it sits flushed with the upper oil pan
alh3010
Nov 1, 2013 01:21 AM
mpoo83
13
Oct 9, 2011 05:45 PM
trmcatee
Nov 25, 2006 05:28 PM
Libtek13
Aug 4, 2004 09:45 AM
KF8TY-Barry
Aug 25, 2000 03:31 AM
