Another quick question regarding the ignition switch on my 95 90qs since I owned it.
Old Dec 16, 2011 | 07:08 PM
duanevw's Avatar
Default Another quick question regarding the ignition switch on my 95 90qs since I owned it.
Here is the sypmtoms I have with the ignition switch since I purchased the car. I had paperwork stating the recall was done at one time also. If I turn the key on or start the car that works fine. If I want to turn the radio on I have to lightly push the ignition key in further so it will catch and stay. Another thing is like the door chimes only chime if the key is pushed in enough or just enough to stay in then the chimes will chime when the door is open. So my question is, is it the plastic ignition switch that plugs behind the lock cylinder? The previous owner noticed this also.
So, do you think I should try a new ignition lock switch and see if thats the problem because the key isnt staying all the way in to make contact like for when you turn the key off for the dom light comes on and chimes and the aftermarker blukpunkt radio.
Thanks for any advice on this small problem, also since i had the car the left turn signal wont cancel out sometimes but I do noticed the steeringwheel isnt point true straight either. It points more to the right when driving if that makes a difference.
Those are just my small quirks memebers. And any suggestions will be much appreciated, I did a search on my quirks but nothining came up with my symptoms. Duane, MI
Old Dec 19, 2011 | 11:46 AM
CRAZY_RUSSIAN's Avatar
u got it man:-) your tumbler might be going out too, but i would do the switch first
IntheQ5
Q5/SQ5 MKI (8R) Discussion
38
Oct 21, 2024 10:43 PM
2005audia6
Sep 8, 2015 11:54 AM
CPLYONS
Sep 7, 2015 07:19 PM
stormchaser1967
New Member Welcome Area
Sep 1, 2015 01:29 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
Sep 1, 2015 09:16 AM
