Fuel Pump Relay
Old Dec 23, 2011 | 01:02 PM
adrianep_98's Avatar
Default Fuel Pump Relay
Hi guys, please anyone knows where specifically is the fuel pump relay for a 1995 Audi 90S 4 dooe sedan? I know it's under the kickpanel, does anyone have the white number on it or the exact location, or the ?
Why? Car stalled mid traffic lost power immediately and I had to push it to safety and park. It cranks, starts, very faintly then dies off. Think it's the fuel pump or the relay since I heard clicks on and off for years under the dash.
Old Dec 23, 2011 | 01:27 PM
CRAZY_RUSSIAN's Avatar
put some gas in the car and replace your fuel filter
Old Dec 23, 2011 | 01:39 PM
Rusky, I like you mano but come on. There's gas in the car but what about the fuel filter?
Old Dec 23, 2011 | 04:46 PM
Prospeeder's Avatar
its under the hood, in the fuse box. They clearly label it on the lid of the fuse box.
Old Dec 24, 2011 | 11:41 AM
Thank you for the input, duh!, should've known that. Replaced the relay, no change, car cranks but doesn't start, I am pretty sure it's the fuel pump, can't hear the pump on crank or on key position 3. It usually buzzes for the pre ignition feed.
Old Dec 25, 2011 | 08:07 AM
lol, sorry, we head a similar situation not too long ago, car would not start, crank, no start. rolled it down a hill to a flat spot, started right up. i told them to go get gas right away, anyways, don't believe your fuel gauge.
your fuel filter is on the right side (passenger)of the car, in front of the right rear wheel, grab a flashlight ;-)
Old Dec 25, 2011 | 08:15 AM
Ok, my VW Beetle, same location. I may not trust the fuel gauge but, I just put gas in the car before it broke down.
The fuel filter, does it have quick release hoses or not? The beetle had, I'm asking because it's cold outside and it'd save me some pin. I'll bring a FLESH light also.
Old Dec 26, 2011 | 03:01 PM
maineman's Avatar
Default Have you tried to pull the codes ?
It may be your cam position sensor.
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 26, 2011 | 04:47 PM
hubturn's Avatar
Just googled it. LOL. Would that be the triple-A battery size FLESH light?
Old Dec 27, 2011 | 10:10 PM
Maineman thank you for the input, the symptoms were dead, on the same for the cam position sensor when it went bad last year, changed it. The only thing that separates this from that is the fact that now, it started twice on cranks but it died off instantly.
Ok guys, here it is, I went today to Audi and it is the fuel pump, not the relay, and not the filter, they checked the circuits and there's no constraint creating a vacuum, there is electricity up to the pump so there is no problem with the relay either.
Thank you for the help, all in all, towing, diagnosis, part and replacement, I'm out a chunk of change, but I guess this was my gift for Christmas.
fluidparkour75
Aug 18, 2018 02:57 PM
smiladon
Oct 1, 2015 01:31 AM
stigg
Audi allroad
Sep 28, 2015 10:37 AM
Panelhead
Sep 28, 2015 06:39 AM
smallbizwhiz
S4 (B8 Platform) Discussion
Sep 24, 2015 11:31 AM
