Smoking oil in back of engine bay. What can it be?
Old Dec 26, 2011 | 03:13 PM
pepe88's Avatar
Default Smoking oil in back of engine bay. What can it be?
I had my hood up today with the car running and smelled oil. When I looked close, I could see a small amount of smoke from the back of the engine bay. It was coming from the middle and maybe a little to the passenger side.
The car doesn't appear to be using oil. I am due for an oil change and have been using M1 0w40. The car is a 2002 225 with APR 93.
Old Jan 3, 2012 | 05:40 AM
The2001TTguy's Avatar
I'm not sure where the camshaft adjusters are in relation to where you're seeing evidence of oil, but I had a problem a while back where the seals on those were going bad. This causes some oil to drip out but in my case I didn't notice the engine "using oil" either. It's just that smoking oil poses a danger of fire, so it's probably a good idea to get that checked on ASAP.
Old Jan 23, 2012 | 11:02 AM
skylordd's Avatar
You can check the boot on your CV joints. I had a CV joint rubber boot go bad and flung grease on the exhaust down pipe. Just something to check as you said there was no oil loss.
Old Jan 23, 2012 | 04:08 PM
mikesquattro's Avatar
Should be a CAM adjuster seal. Seen that before..
IntheQ5
Q5/SQ5 MKI (8R) Discussion
38
Oct 21, 2024 10:43 PM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
Sep 11, 2021 04:04 PM
Boosted01tt
1.8T Discussion
Jan 3, 2017 05:55 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
Sep 1, 2015 09:16 AM
ECS Tuning-Audi
Sep 1, 2015 08:27 AM
