Window radar detector placement recommendations
Any suggestions?
Any suggestions?
I have a v1 and got tired of all the false alerts so I just purchased a 9500ix. My v1 came with a hardwire kit, whereas the 9500ix requires an separate kit. You can purchase the Direct Wire SmartCord ( Mfg Part# 79-000041-01) http://www.buydig.com/shop/product.a...E&tab=descript
Also, the suction cups on the v1 are TERRIBLE. If you ever have to take it off, it's a good 5 minutes trying to get it to resuction. For the 9500ix, i found a pretty cool suction cup that works awesome: ( Mfg Part# 0010027-1) http://www.buydig.com/shop/product.a...P&tab=descript
As far as hardwiring goes, I believe you will need to run above the hoodliner, down the A-pillar, and then tap into the fusebox.
Just found a good Valentine v1 Stealth install for the TT, hope this helps. I woudl imagine the 9500ix would be very similar: http://forums.fourtitude.com/showthr...-Install-(BWW)
Matt
Any suggestions?
Here is a concealed install for a V1. I assume logic w/b the same on the 9500ix. Good write-up:
http://www.audi-forums.com/1998-2006...-hardwire.html
