90 CQ Idle seems very low when starting?
Old Jan 7, 2012 | 07:52 PM
snowchaser's Avatar
Default 90 CQ Idle seems very low when starting?
When I start the CQ it takes a bit of cranking and then the RPMS zoom up nicely for a few seconds however quickly drop to the stall point unless I rev the engine. Also, when cold if I come to a stop light the car will rev up for a second and then rev down and often stall. Any thoughts?
Old Jan 8, 2012 | 05:27 AM
merton1973's Avatar
does it have an idle control valve? or cold start sensor? which engine do you have?
Old Jan 8, 2012 | 11:23 AM
varia's Avatar
coupe has ICV, bosch or hitachi and only one engine: I5 2.3 20v n/a (7A)
Old Jan 8, 2012 | 01:03 PM
merton1973's Avatar
maybe this site can help you. http://20v.org/engprob.htm#coldstart
Old Jan 8, 2012 | 02:05 PM
duanevw's Avatar
If everything has been ok just lately, then I will assume its the ICV (idle valve, I always cleaned the carbon tracks out of my older Audi's, and VW's and if that didn't work then I pulled the trusty Fluke out for testing on the pins on the valve. Other than that its vaccumm lines or a torn flow sensor boot by experience. Lots of guides about this as you have a good link up above.
IntheQ5
Q5/SQ5 MKI (8R) Discussion
38
Oct 21, 2024 10:43 PM
eggsngrits
Dec 8, 2021 06:58 PM
Boosted01tt
1.8T Discussion
Jan 3, 2017 05:55 PM
saifxnyc
9
Nov 30, 2015 12:32 PM
rammstien80
2.7T V6 Discussion
Sep 4, 2015 04:26 AM
