how to remove that pesky connector
Old Mar 22, 2012 | 06:18 AM
clancy's Avatar
Default how to remove that pesky connector
I am going to replace my coolant temp sensor this weekend. I tried to remove the electrical connection plug earlier and was stymied. Granted it is not in the easiest location. I have always had problems with this particular connector, on the brake pads and in other locations. What is the proper and easy way to remove this plug?
Old Mar 24, 2012 | 10:00 AM
Just Me's Avatar
Tech Guru
Tech Guru
i have a write up posted on the tech section. I think i have pics of it apart. As i recall its different from the brakes - its a push the locking tab while pulling, and, yes, its a PITA. But check the write up - its more permanent than my memory at the moment!
G
Old Mar 24, 2012 | 10:43 AM
bigdadi's Avatar
You can remove the coolant temperature sensor from its seat first. After that take care the connector.
Old Mar 24, 2012 | 05:14 PM
ezveedub's Avatar
That's if the sensor is not stuck. If so, you will want to remove the connector so you can pull the sensor out with pliers. Trying to pull on the connector to get the sensor out will break the connector in most cases.
Old Mar 24, 2012 | 09:28 PM
OGBULLYLOCDAWG's Avatar
Use a hose pick (or the top of a clothes hanger). Pull up the release clip/tab, then, while holding the clip/tab up, pull the connector off.
Normally you'd just put a flat-head into the slot and turn to release that locking clip/tab thing, but I couldn't get a flat-head on it @ the temp sensor location.
Video on how to remove the connector that I found a while back, unfortunately I don't remember who posted it to be able to credit them for it. Made it really simple for me:
<iframe src="http://www.zshare.net/videoplayer/player.php?SID=dl091&FID=99467868&FN=headlight_cli p.avi.flv&iframewidth=648&iframeheight=415&width=6 40&height=370&H=9946786841c92459" height="415" width="648" border=0 frameborder=0 scrolling=no></iframe>
Old Mar 26, 2012 | 05:52 PM
Airbag's Avatar
fail
Old Mar 26, 2012 | 08:26 PM
I guess youtube is the only reliable way.
http://www.youtube.com/watch?v=dv__T7ZxwgQ
(credit to the original uploader)
Old Mar 27, 2012 | 06:45 AM
clancy's Avatar
Thanks for all the advice. I get it now.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 27, 2012 | 07:09 AM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
I would NOT turn the screwdriver...as you can see from the video it distorts the tab and generally breaks it...the way to do it is to put the right width screwdriver in the slot and move the screwdriver such that the entire width of the screwdriver lifts up the tab. The strong part of the tab is on the outside edges...if you pry up the inside it will often break rather than bend as it shows in the video.
YMMV.
Old Mar 28, 2012 | 05:08 AM
Boston Driver's Avatar
AudiWorld Expert
Many connectors release if you push them in tighter first, then pull. Works that way for the foglight connectors, wear sensors, etc.
Steven Lin
Dec 24, 2007 05:53 AM
eug (MK V)
Dec 8, 2005 03:02 PM
davenew
May 17, 2005 03:50 PM
DocWyte
Mar 8, 2005 06:51 PM
GOOOO
Mar 29, 2004 09:17 AM
