'01 A6 2.8 Quattro Wierd no start
What could have caused that?
Thanks
Steve
Not sure what he meant by the "security system" - the immobilizer is actually part of the instrument cluster. I'd try to find someone with a VAG-COM and see what codes are in the system (unless they cleared them all). Even momentary ones are stored. If you get them, post them here and we'll see if we can help figure it out.
Kinda sounds like they disconnected or triggered something without realizing it, and then fixed it again so it started. You should try to figure out what it was, though, in case it's something loose that may happen again...
Jim
Learn something every day!
Have a nice day
Steve
Any ideas?
Thanks
Steve
Maybe the third time will be the charm:
You need to scan the central locking control module for codes and use measuring blocks to check the operation of the alarm system and the various trigger switches. The generic scanners are not getting this done. Scanning the ECU is a waste of time if the alarm is preventing the car from starting.
What type of scanner do I need to use and who has them? What are these "measuring blocks?" I appreciate your help with this issue. I have little Audi experience.
Thanks
Steve
Thanks
Steve
You need VAG-COM to connect to central locking. Measuring blocks will show you the operation of each switch and button from the control unit's point of view.
