Old Aug 15, 2016, 10:07 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C5) Interior Guides
Print Wikipost
No Windows/Alarm/Door locking/Sunroof Door Issue
Old Apr 1, 2012 | 11:09 AM
lscheres's Avatar
Default No Windows/Alarm/Door locking/Sunroof Door Issue
Ok so this is wierd, last night i went out, parked my car, everything was fine.... When i came out of the bar 3 hours later, went to grab something shut my door and locked it.... I then noticed the alarm didn't set??? I thhought my drunk *** hit the trunk button as usual.... Nope it was shut... The car was locking but not arminng the alarm. So i said **** it, made sure it was locked the got my ride home that was waiting for me.... The next morning i went to pick the car up, i got in started it and up comes up on the dashboard, it thinks ALL the doors EXCEPT the drivers door are open. Which is funny since the drivers door was the only one that had been opened that entire night. Along with it not recognizing the doors, it recognizes the drives door just fine BTW, the windows wont roll up or down, the interior lights wont come on car off or on, key in or out, no interior lights except night time red dash/stereo/ac lights. I pulled the Vag codes but heres were it gets wierd.. It doesn't really show much, I'm pretty sure these codes are from when i got side swiped LAST YEAR. I didn't clear the codes for the locks ever, that i can recall... So i cleared the code and am going to go for a drive and do some errands. Ill post back in an hour or two with new codes if they show up. I rescanned after i cleared the codes, after trying to lock doors, shut/open doors, etc.. nothing showed up so ill give it a little i guess. Heres the vag codes for the central locking.
Code:
Sunday, 01 April 2012, 11:33:48
VAG-COM Version: Release 409.1-US
Control Module Part Number: 4B0 962 258 M
  Component and/or Version: Central Lock/Alarm  D38
           Software Coding:
            Work Shop Code:
5 Faults Found:
01366 - Opened Due to Crash Signal
        35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
        35-00 - -
01374 - Alarm triggered by Terminal 15
        35-00 - -
01570 - Turn-Off Delay: Terminal 15
        29-00 - Short to Ground
01560 - Passenger Door
        59-10 - Can't Unlock - Intermittent
Old Apr 1, 2012 | 11:13 AM
lscheres's Avatar
I did check the wires in between the drivers door and frame, pulled the boot back and my wires still look brand new, no cracks i could see. Next is the comfort control module correct??? Its under some panel in the passenger floor area??? I found a couple threads about people with A4's with the same issue, lol not really what i was planning on doing hung over this morning...
Old Apr 1, 2012 | 12:38 PM
kickstand80's Avatar
Default Convenience Module
The convenience module is under the carpet directly in front of the drivers seat. It is in a recess area in the floor. Many people have had water get into this area and cause all sorts of odd problems with the module. My personal experience was a bad power wire (there are 2) and had to run a new wire. I have also had a shorted switch inside the drivers seat that kept blowing fuses (#14 I think) that caused the windows and sun roof/alarm/interior lights ect. not to work. I unplugged the wire harness for the seat and the blown fuse went away. I will try to post a wire diagram for your car
Old Apr 1, 2012 | 12:56 PM
Default Convenience Module wire diagrams
for 2004 A6 2.7
File Type: pdf
File Type: pdf
Old Apr 1, 2012 | 01:10 PM
4Driver4's Avatar
Tech Guru
Tech Guru
I'd probably do some testing with VAG-COM before tearing anything apart.
Old Apr 1, 2012 | 03:57 PM
lscheres's Avatar
Default Vag Scan
Code:
Sunday, 01 April 2012, 16:51:02
2 Faults Found:
        59-00 - Can't Unlock
Ok so i have a short somewhere, in the passenger door?? Im google-ing the codes right now in the mean time. Thanks for the help!
Old Apr 1, 2012 | 04:08 PM
lscheres's Avatar
Default Blown fuse 14, thought i checked it
but i guess im blind lol, replaced it and it hasn't blown yet. No just to figure out what it the notorious fuse 14 short, so far i've found it could be a list of things from my footwell light to my Homelink having a short lol..... Thanks for watching me figure it out, i'm sure one of these times i will need some serious help
Old Apr 1, 2012 | 05:33 PM
4Driver4's Avatar
Tech Guru
Tech Guru
[CODE]
More to VAG than scanning codes. Measuring blocks!
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 3, 2012 | 06:35 AM
Boston Driver's Avatar
AudiWorld Expert
My guess is the footwell light, which is more common fault for fuse #14. Just reach up under the driver seat and unplug the two-wire black connector which is for the rear footwell light. That wire sometimes shorts because of issues with the inside of the driver seat...old wiring coming into contact with something metal inside the seatback frame.
Good luck!!!
myers1.8TQ
Apr 11, 2008 04:36 PM
huwla
Apr 23, 2006 08:21 AM
huwla
Jan 14, 2003 11:30 PM
mluszcz
Apr 30, 2001 02:27 PM
