Stupid Timing Chain Tensioner Pads
Everything was going fine until a bolt broke off while I was tightening the valve cover (7 ft/lbs) on the passenger side. No biggie. It was still a pleasant experience up to that point.
Then midway through the driver side I find out that the cam chain tensioner pad is cracked and missing some pieces. What a POS! It wasn't what I needed after putting in a few hours of back breaking work! I'm not sure how much of the missing pieces are still in the chamber, but I tried to fish them out as much as I could. It was a disaster just waiting to happen. This might explain some of the ticking noise that I've been hearing. I hope that my timing is not affected by my replacing this tensioner pad. Any ideas from you Audiworld gurus on this subject?
Anyway, I found an auto parts place on Amazon who sells the pads only for $22.95 (plus $32.06 FedEx Overnight). The shipping costs more than the part. LOL!
Local auto parts stores and the dealership only sell the cam chain tensioner as a whole unit.
Here's the culprit:
<a href="http://www.flickr.com/photos/targuevara/7051340915/" title="Cam Chain Tensioner Pad by Tar Guevara, on Flickr"><img src="http://farm8.staticflickr.com/7277/7051340915_81d5c66c79.jpg" width="500" height="348" alt="Cam Chain Tensioner Pad"></a>
Here's the cam chain resting on the tensioner without the pad:
<a href="http://www.flickr.com/photos/targuevara/7051340937/" title="Cam Chain & Tensioner by Tar Guevara, on Flickr"><img src="http://farm8.staticflickr.com/7075/7051340937_862f30763a.jpg" width="500" height="333" alt="Cam Chain & Tensioner"></a>
I'd appreciate any helpful hints from you Audiworld gurus! Thanks!
Here's the culprit:
Are you asking for the replacement procedure?
http://youtu.be/DEOC8zFOHcQ
http://www.amazon.com/97-06-Timing-C.../dp/B002S65MGG
that your working with and the tool will compress the pad to do the repair.
Thats all.
STFA...the procedure is there. Main thing is to get the cam chain sprocket back in exactly the same place...mark the chain/sprocket with magic marker or scribe.
If you just want to flip the car you could put just the top pad in...but you won't be doing yourself any favors in a couple thousand miles when/if the other three pads go.
In the time honored fashion of DFWAB, the broken pad is symptomatic....
I would pull the cams and replace them both on that side at least. It sucks - you will have to take the timing belt off to do this. This is why it's good to do this service when you do the timing belt. There's always something that goes wrong that could make you have to do the other half....
