Rear diff mod???
Old Dec 20, 2012 | 10:31 AM
CRAZY_RUSSIAN's Avatar
Default Rear diff mod???
who knows which blue/white wire to cut for the rear diff mod? and which module under the rear seat (part number or picture)? thanks in advanced
Old Dec 20, 2012 | 02:25 PM
egp320i's Avatar
Banned
What mod are we talking about? ETKA does not show any wires to the diff. The locking runs on vacuum and there are two lines.
Old Dec 20, 2012 | 02:56 PM
there is a wire that we can cut that stops the diff from automatically disabling the lock after 17mph
Old Dec 21, 2012 | 10:50 AM
Luxus Panzer's Avatar
if you cut it.....add a switch and re connect.
this way you can choose when the diff stats on over 25km/h
you may not want it in 24/7 on pavement...you will blow the diff
Old Dec 21, 2012 | 12:56 PM
i know man:-) im planing on doing some major skiing up in Colorado area, and i could use the locked rear in those areas, and the only time i got stuck with this car, the auto disengage was not helping at all
Old Dec 22, 2012 | 09:32 PM
duanevw's Avatar
Default mod?
I didn't know the B4 used a vacuum line any more like the older models for locking the diff? I guess it does if you have the manual..
That would be one deadly Mod, it will be one nice German Tank in the Mountains Russian!!
Duane
Old Dec 23, 2012 | 12:06 AM
egp320i's Avatar
Banned
Here is the schematics
<a href="http://tinypic.com?ref=1zn7w1y" target="_blank"><img src="http://i50.tinypic.com/1zn7w1y.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Old Dec 29, 2012 | 12:33 PM
GuyllFyre's Avatar
Lift up your backseat and look for the module with two vac lines going to it. The vac lines are black and one has a blue stripe and one has a yellow stripe. Find the only blue and white wire and snip/switch it and you are done.
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 29, 2012 | 12:35 PM
GuyllFyre's Avatar
On this note, does anyone know if the rear locking differential can be transplanted into the newer B5 A4?
I know a locking mechanism will need to be devised but with the winter snow and ice here and having both cars, was wondering if I could swap things around.
Old Dec 29, 2012 | 12:36 PM
GuyllFyre's Avatar
