Ball joint nut and pinch bolt size.
Old Jan 23, 2013 | 01:16 AM
Pope's Avatar
Default Ball joint nut and pinch bolt size.
Hey everyone,
Am going to change the ball joints on my 1996 cabriolet and was wondering what the size of the three nuts that hold the ball joint on are. Also need the pinch bolt and nut sizes as my ball joint did not come with any nuts or bolts.
Thanks
Old Jan 23, 2013 | 09:14 AM
CRAZY_RUSSIAN's Avatar
use your old ones? or go to a hardware store with the ball joint in hand
Old Jan 23, 2013 | 01:48 PM
Pope's Avatar
I like to have all the parts with me before I start a project.
Old Jan 24, 2013 | 06:27 PM
yodasfro's Avatar
The pinch bolt and nut should really be replaced every time you remove them.
N0347784 M10x50x24 pinch bolt
N0211955 nylock nut for pinch bolt can used for the BJ lower mounting studs too.
N10286110 shouldered self locking nut M10 serves same purpose as above slightly cheaper and you may get sent them when you order the nylock version
due to supercessions anyway.
Some new ball joints come w/ hardware depending on brand.
http://genuineaudiparts.com
Old Jan 28, 2013 | 02:38 PM
Pope's Avatar
Thanks for your help, that is just what I needed. My Ocap ball joints did not come with bolt or nuts.
Old Feb 9, 2013 | 02:48 PM
Pope's Avatar
For future reference to other owners, the ball joint nuts and the pinch bolt nut are grade 10, M10 x1.5
The pinch bolt is grade10, M10x1.5x50 with a 24mm shoulder for the ball joint.
Ribbed Flange nuts are recommended by Audi to replace the previous nut with washer. This will up the torque to 63ft/lb with the ribbed flange nuts, and washer is no longer needed.
bgd
Audi allroad
Aug 11, 2009 05:59 PM
my2000apb MEGABOOST
Jun 9, 2008 08:42 AM
BlackS4inNNJ
Mar 24, 2008 07:10 AM
victor army
12
Feb 18, 2007 09:35 PM
petersthompson
Jun 20, 2002 10:46 AM
