Is there a correct side up for front springs?
Old Jan 5, 2014 | 12:53 PM
ivonius4.2's Avatar
Default Is there a correct side up for front springs?
The front suspension (over-the-strut) springs look identical at each end. Does anyone know different?
Old Jan 5, 2014 | 10:22 PM
A6Gary's Avatar
Suggest you measure the outer diameter of each end. If both ends measure are the same, and have the same end design (e.g., round, ground flat, etc.), then there probably isn't any difference which way you install the spring.
rsixxer23
Jan 6, 2016 03:25 AM
DjPiLL
S6 / RS6 (C7 Platform) Discussion
Nov 1, 2015 05:22 PM
Dudealicious
Q5/SQ5 MKI (8R) Discussion
Sep 12, 2015 03:51 PM
kclee1st
Sep 5, 2015 09:35 PM
Dudealicious
11
Sep 5, 2015 08:58 AM
