New VagCom Report
Battery has been disconnected/reconnected. Throttle body has been off. ECU has been unplugged and replugged.
Address 01: Engine Labels: 8D0-906-266.lbl
Part No: 8D0 906 266 B
Component: 2,8l V6/2V MPI OBD2 D03
Coding: 10242
Shop #: WSC 02324
VCID: 2B5542C8D90E5279EBD-5140
No fault code found.
Readiness: N/A
Address 02: Auto Trans Labels: None
Part No: 4A0 927 156 AL
VCID: 70EF95A430A871A19EF-4A22
2 Faults Found:
00296 - Kick-Down Switch (F8)
29-10 - Short to Ground - Intermittent
00526 - Brake Light Switch (F)
27-00 - Implausible Signal
Address 03: ABS Brakes Labels: 4D0-907-379-ABS.lbl
Part No: 4D0 907 379 L
Component: ABS/EDS BOSCH 5 4171
Shop #: BB 34171
VCID: 377D6EB81546E6999F5-FFFF
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 08: Auto HVAC Labels: 4A0-820-043.lbl
Part No: 4A0 820 043 K
Component: Klima-Vollautomat D05
Coding: 00162
Shop #: WSC 02324
VCID: 2149A0E0ABC28829411-257A
Address 15: Airbags Labels: 8A0-959-655.lbl
Part No: 8A0 959 655 D
Component: Airbag V AUDI D01
Coding: 00127
Shop #: WSC 02324
VCID: 346759B404300D81BA7-5210
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 4Ax-919-03x-17.lbl
Part No: 4A1 919 035 CN
Component: C4-KOMBIINSTRUMENT D30
Coding: 00262
Shop #: WSC 06412
VCID: 72EB9FAC3EA443B168B-1DEA
No Faults Found
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8LO 862 257 B
Component: CV-Pump,Alarm, RC
Coding: 12172
Shop #: WSC 65535
VCID: 53A53A28A1FE2AB983D-4ECE
16 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01361 - Switch for Anti-Theft Alarm; Close
29-00 - Short to Ground
01360 - Switch for Anti-Theft Alarm; Open
01362 - Close Switch for Tailgate/Trunk (F124)
01363 - Switch for Central Locking; Driver's Door (F59)
01364 - Switch for Central Locking; Passenger Door (F114)
01365 - Lock/Unlock Switch; Interior
28-00 - Short to Plus
End-------------------------(Elapsed Time: 02:00)--------------------------
