New VagCom Report
New VagCom Report
Hello all. I'm a long time lurker - first time poster.So, I broke down and bought the Ross-Tech scanning tool...below is the report. Car starts fine...shimmys and shakes a bit in neutral which turns into a full on shake upon placing it into gear. I've just pulled my Idle Air Control Valve thinking I could/should clean it. The seat for the IAC was easy to clean...then I managed to get some MassAirFlow cleaner into the IAC valve and I can hear it sloshing around in there but there appears to be no way of getting it out of there?!! ANY and EVERY suggestion(s) as to how to proceed with both the IAC valve situation AS WELL AS the items found in the report below - would be GREATLY appreciated. Thanks. Jake in NC. Oh, and Happy Mother's Day to all you Gearheads' Moms.
Battery has been disconnected/reconnected. Throttle body has been off. ECU has been unplugged and replugged.
Address 01: Engine Labels: 8D0-906-266.lbl
Part No: 8D0 906 266 B
Component: 2,8l V6/2V MPI OBD2 D03
Coding: 10242
Shop #: WSC 02324
VCID: 2B5542C8D90E5279EBD-5140
No fault code found.
Readiness: N/A
Address 02: Auto Trans Labels: None
Part No: 4A0 927 156 AL
VCID: 70EF95A430A871A19EF-4A22
2 Faults Found:
00296 - Kick-Down Switch (F8)
29-10 - Short to Ground - Intermittent
00526 - Brake Light Switch (F)
27-00 - Implausible Signal
Address 03: ABS Brakes Labels: 4D0-907-379-ABS.lbl
Part No: 4D0 907 379 L
Component: ABS/EDS BOSCH 5 4171
Shop #: BB 34171
VCID: 377D6EB81546E6999F5-FFFF
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 08: Auto HVAC Labels: 4A0-820-043.lbl
Part No: 4A0 820 043 K
Component: Klima-Vollautomat D05
Coding: 00162
Shop #: WSC 02324
VCID: 2149A0E0ABC28829411-257A
Address 15: Airbags Labels: 8A0-959-655.lbl
Part No: 8A0 959 655 D
Component: Airbag V AUDI D01
Coding: 00127
Shop #: WSC 02324
VCID: 346759B404300D81BA7-5210
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 4Ax-919-03x-17.lbl
Part No: 4A1 919 035 CN
Component: C4-KOMBIINSTRUMENT D30
Coding: 00262
Shop #: WSC 06412
VCID: 72EB9FAC3EA443B168B-1DEA
No Faults Found
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8LO 862 257 B
Component: CV-Pump,Alarm, RC
Coding: 12172
Shop #: WSC 65535
VCID: 53A53A28A1FE2AB983D-4ECE
16 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01361 - Switch for Anti-Theft Alarm; Close
29-00 - Short to Ground
01360 - Switch for Anti-Theft Alarm; Open
01362 - Close Switch for Tailgate/Trunk (F124)
01363 - Switch for Central Locking; Driver's Door (F59)
01364 - Switch for Central Locking; Passenger Door (F114)
01365 - Lock/Unlock Switch; Interior
28-00 - Short to Plus
End-------------------------(Elapsed Time: 02:00)--------------------------
Coding: 10242
Shop #: WSC 02324
Readiness: N/A
2 Faults Found:
Shop #: BB 34171
No Faults Found
Coding: 00162
Shop #: WSC 02324
Coding: 00127
Shop #: WSC 02324
1 Fault Found:
Coding: 00262
Shop #: WSC 06412
No Faults Found
Coding: 12172
Shop #: WSC 65535
16 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
So, I'd inavertantly reset the codes. When I tried to take it for a spin I got a series of 300 codes with misfires in the number 5, and 6 as well as a random 300 code. I pulled the egr and they thing was apparently sticking - so I cleaned the sumbeech and I've managed to fix my stammering/shaking/misfiring problem. Thanks California, and all you granola types - I wouldn't know what to do with any more emission bullsh!t on my vehicle.
socaliA4
06-01-2004 03:52 AM
privatejoker
05-30-2003 07:49 PM
SteveK-O (stock!)
02-16-2003 02:35 AM
