Horsepower boost
Old Aug 14, 2015 | 11:24 AM
Mels's Avatar
Default Horsepower boost
The 2015-2016 3.0T are rated approximately 30 horsepower higher than the 2014 A7. Does anyone know if the increase in hp is a function of engine tuning or have the engines been "modified" from the factory ?
Thank you
Old Aug 14, 2015 | 02:20 PM
jjsC6's Avatar
I don't know, but I'd bet money it's tuning. It has no more peak torque, so all they had to do was hold the boost a few hundred more RPMs and tweak timing and fuel delivery.
Old Aug 15, 2015 | 08:19 AM
chicagoA6's Avatar
I agree... Tuning. Car manufactures love to hold back some HP for refresh models
In the US the 2016 has the HP increase. The 2015 was the same as the previous models @ 310
Old Aug 15, 2015 | 11:21 AM
lawtq's Avatar
Yeah tuning mostly I think I read somewhere, examples are injectors delivering fuel at a higher pressure, newer coating on the piston rings causing less friction blah blah, slight stronic gearbox improvement. Mostly just mapped higher?
They like to keep these things so damn secret. I want to find more in depth info but can't. erWin is the best place for diy but I want info on changes
Old Aug 15, 2015 | 06:11 PM
Astropin's Avatar
This model still has a TON of headroom. So 340 in the 2016?
They could easily bump this engine to 370+
Old Aug 17, 2015 | 03:46 AM
Mels's Avatar
Thanks for the feedback... Now I'll check to see if Audi will be willing to make some of these adjustments. Should be interesting !!
Old Aug 17, 2015 | 07:40 AM
19hole's Avatar
Given the V6 is the same engine that is used in the S5 and that has been at 333 BHP, I think that they are just using the same tuning in the A6/A7 as they always have in the S5.
Old Aug 22, 2015 | 09:18 AM
Mels's Avatar
Scary enough...Audi responded once that the heads "may be" different and the second time they called me back, they thought it is only a tuning issue.
Audi of America was no help whatsoever and referred me to the dealer.
To be continued.....
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 30, 2015 | 09:56 AM
HaveBlue's Avatar
The boost controller starts to open at 4500 rpm. Basically kills the top end of the motor. Easy to get a bunch more power out of it. The problem for Audi is that it then gets into the same power to weight ratio as the S7.
Here's a good graph
Mels
3.0TFSI Engine Discussion
Aug 29, 2016 09:21 PM
Mels
Aug 9, 2015 04:38 AM
PaulW
16
Jan 26, 2005 02:39 PM
derek2079
Jul 31, 2004 06:33 PM
jsyang15
Mar 26, 2003 06:37 AM
