2012 Audi a7 retrofit to 2016 facelifted.
When I connected headlights to 14pin connector there are few things mixed with lightening:
- I DRL running properly
- I got turn singal instead of high beam
- I got only one part of low been active. The second sector is not running.
I tried mixing with wiring and was able to make turn signal working properly, but not able to run high beam properly.
I believe somoe coding is needed here as old full leds were slight different (3 sectors instead of 4 in new one).
I got VCDS and this is orginal long coding from 09-Cent-Elect module.
0D072091073E9FE281000884A0003820CF9CD208A209012580 0308453B00
Can anyone run a scan on facelifted model and share please?
I think this one would be very beneficial.
Your comments are very welcome.
Cheers.
The problem I've got now are headlights. Not sure if only wiring changes are needed or some codding would also shall happen. I had full led headlamps before and changing for facelifted full led. I know they are slight different (2 low beam sectors and 2 high beam sectors) but it still full led.
What you think Guys?
I also did a measure on each PIN from existing connector to have kind of good starting point.
and this is how the lamp looks like:
At this point I would like which PIN should go where and what is purpose of PIN 14 giving 8,5 (or 9V due to battery condition) no mater of ignition/switch position.
I also want to make a facelift
And Do you have any instructions on this DIY project. My front bumper on my A7 needs replacement and i don't mind buying 2016 bumper if it can be done. Thanks
Hope you figure out the lighting issue..
Cheers.
did you need to amend anything with the slam panel or rad pack
