Need Help ASAP.!?!?
Old Jul 27, 2016 | 09:10 AM
mohanshergill's Avatar
Default Need Help ASAP.!?!?
I have recently bought a 2001 Audi TT 1.8. It is a manual. Whenever i press the gear selector down and try to go in reverse it goes in 1st gear. Once in like 50 times it will go in reverse. The previous owner told me replacing the clutch will fix it. But I get into 1st,2nd,3rd,4th,and 5th gear no problem with the clutch. I called a local shop they said it can be a Shifting cable. My question is Do i need to replace the clutch to solve the reverse issue. If not what is a cheaper solution to this problem. I drives perfectly just reverse is the issue.
Old Jul 27, 2016 | 05:18 PM
rriicckk's Avatar
Do you get a clean break from the engine to the transmission when you press in the clutch pedal? No grinding - no movement when stopped - easy to reach the other gears? If so, then it's unlikely to be a clutch issue. Can you locate reverse using the fork controls directly on the transmission? You are likely experiencing wear in the linkage.
Old Jul 28, 2016 | 04:21 AM
Walpole5's Avatar
I'm new to TT's, but in one of my older Audis, you could adjust the shifter gate. We had trouble getting into first gear until I adjusted it and then it was like butter.
Old Aug 6, 2016 | 01:58 PM
Mister Bally's Avatar
Buy the service manual and follow the procedure to adjust the sfit cables/linkage. Also verify the clutch is functioning properly. Bleeding it is a bitch without a high pressure pressure bleeder. My Snap-On model wouldn't cut it until I boosted pressure with regulated shop air.
wlgaddey
Audi A3 / S3 / RS 3
Feb 5, 2008 07:31 PM
DB/S4
26
Sep 18, 2007 07:30 AM
Don fvcking Juan
May 2, 2007 09:00 AM
T-28-Quattro de VT
Aug 27, 2001 03:54 PM
