Window drop on open
Old Nov 15, 2016 | 04:51 PM
97urS6's Avatar
Default Window drop on open
Normally, when I open the driver door the window will drop about half an inch, and then when you close the door, it pops back up into place. Mine stopped doing that recently? The passenger door/window still works correctly.
I recently had a mechanic install a stock 6-disc CD Changer in the rear seat slot behind the driver seat... but he wouldn't have done anything with the driver door?
Not sure if that is a co-incidence or not (I'm sure that is what they will claim).
Is there a relay or something that controls that function separate from the same function on the passenger door?
Any suggestions would be helpful.
Old Nov 15, 2016 | 05:10 PM
Mister Bally's Avatar
There is a microswitch on the door latch that sends a signal to the control module. The microswitch is known for going bad.
Old Nov 16, 2016 | 03:37 AM
97urS6's Avatar
Back when I got the car in August this year, I had to replace the driver door latch, as the door would bounce open if closed to hard, that solved that problem... would that microswitch be part of that part?
Old Nov 16, 2016 | 12:49 PM
97urS6's Avatar
Ok, so I fixed the problem! Somewhere along the line the mechanic disconnected the battery... apparently this will disable all of the "convenience" functions on the doors/windows! The Bentley manual has a full page of manual steps that you can follow to re-activate all of those convenience functions.
They include:
- one touch down for Windows by power switch
- one touch up for Windows by power switch
- convenience open with key in driver door lock, hold to unlock and both windows open
- convenience close with key in driver door lock, hold to lock and both windows close
- window pop down 0.5" on opening door
- window pop up 0.5" on closing door
Old Nov 17, 2016 | 03:57 AM
tryppyr's Avatar
The owner's manual actually describes the procedure for resetting the windows to AUTOMATIC mode. Very simple.
1) Roll the window all the way down
2) Roll the window all the way up and release the switch
3) Press the switch as if rolling the window up again (you should hear a slight thunk as the auto feature reactivates)
You'll need to do it on the passenger window as well.
tschoppe
Aug 14, 2017 07:11 AM
eatumup
Apr 23, 2013 09:56 AM
BTTI
May 15, 2005 12:27 PM
Black A4TQ
Australia Discussion
Dec 19, 2002 04:27 AM
