Window drop on open
I recently had a mechanic install a stock 6-disc CD Changer in the rear seat slot behind the driver seat... but he wouldn't have done anything with the driver door?
Not sure if that is a co-incidence or not (I'm sure that is what they will claim).
Is there a relay or something that controls that function separate from the same function on the passenger door?
Any suggestions would be helpful.
They include:
- one touch down for Windows by power switch
- one touch up for Windows by power switch
- convenience open with key in driver door lock, hold to unlock and both windows open
- convenience close with key in driver door lock, hold to lock and both windows close
- window pop down 0.5" on opening door
- window pop up 0.5" on closing door
1) Roll the window all the way down
2) Roll the window all the way up and release the switch
3) Press the switch as if rolling the window up again (you should hear a slight thunk as the auto feature reactivates)
You'll need to do it on the passenger window as well.
