RS3 break in procedure
"Breaking in:
A new vehicle must be broken in for the first 1,000 miles (1,500 km). Do not drive at speeds that will exceed 2/3 of the maximum permitted engine speed (RPM) for the first 600 miles (1,000 km), and avoid full acceleration during this period . You may gradually start increasing the RPM and the speed between 600 miles (1,000 km) and 1,000 miles (1,500 km) . During the first hours of use, the engine has a higher internal friction than later on when all moving parts have settled into place with each other.
How the vehicle is driven during the first 1,000 miles (1 ,500 km) also affects the engine quality. Drive at moderate engine speeds after the initial break-in period, particularly when running a cold engine . This will reduce
engine wear and improve the mileage. Do not drive at too low of an engine speed (RPM). Shift down if the engine stops running "smoothly". Extremely high engine speeds are automatically reduced ."
Engine break-in has been, and probably will always remain a source of contention among gear heads. For me personally, warming an engine up / cooling it down properly is always important and NOT using cruise control (constant RPM's) during engine break-in are the most important considerations IMO.
I am actually far more inclined to believe that than the generic break-in instructions provided in the A3 manual with no RS3-specific comments. Did you guys also notice the instructions for your new brakes? Something like "drive gently for the first 500 miles" - yeah, that's written by the lawyers, not the engineers. Go look up Stoptech or Brembo brake bedding instructions
No, the lawyers will never allow the owners manual to tell people the proper brake bedding procedure, so the "factory" instructions are inferior.Remember, lawyers write owners manuals, not engineers!
OK, to be fair, the engineers might write the first draft, then the lawyers review and say "we can't say that, let's be safe and say this". (I hate lawyers... I am a mechanical engineer)The RS3 engine uses a new plasma coating process in the aluminum cylinder bores - there sure as hell is no metal on metal rubbing in the initial running of the engine. This is 2017, not 1957! Tolerances and machining finishes are designed to much tighter clearances and finishes directly from the factory assembly line, the final desired finish in the cylinder bores and on the rings is present when the engine is assembled, not 1,000 miles later.
That said - I haven't let mine run to redline or the rev limiter, and I haven't tried launch control yet. I will be well past 1,600 km before I try those. That's more mechanical empathy than slavish following of lawyer's CYA dictates, however.
Check out that oil pan on the first change - sparkly as a striper's skin for sure.
Question I would ask, why NOT break it in?
[quote]Question I would ask, why NOT break it in?[/QUOTE]
Exactly !!!
