New "short" fuse 15 blows, "fuse" over odometer, Battery Icon
2003 RS6, new problem. I have a short somewhere in the dash. Only recent work was replacing the connector at the head light switch and I replaced the battery about 3 weeks ago. The car was fine for three days.
Then I got a "Battery" Icon warning (the yellow battery symbol) and the word "Fuse" over the odometer and the in dash voltmeter is pinned to the left (zero). The car runs fine. No power issues. Car starts fine 12 hours later.
I found fuse "15" (10 amp) was blown and if I replace it it blows immediately.
Bentley manual shows fuse 15 connecting to the dash instruments, but not specifically to the Voltmeter.
So is it a blown component? Or a new short somewhere?
I wish I had a good diagram of where all the wire harnesses are routed in the car to figure an approach to track down the particular short.
I'll do a Vag Com Scan and post more.
Thank you for any input. (RS6.Com people seem uninterested LOL)
Mike
I
Removing the lower dash panel is easy...there are a ton of references for how to do that. Take a peek and let us know what you find!
I inspected the wire harness to the head light switch and every other wire I could see and there were no frayed wires or damaged insulation around any wires.
No felt either! LOL.
Mike
https://www.audiworld.com/forums/a6-.../#post24389035
