Audi A6 won’t shift from park, brake lights work. TCM?
Old Mar 13, 2018 | 03:17 AM
Awkwardncounter's Avatar
Default Audi A6 won’t shift from park, brake lights work. TCM?
My Audi is a recent purchase(used) last week I parked it, then the next day I got in , and will not shift from park. The brake lights work so I know it’s not the brake light switch. I was wondering if it is 100% the transmission control module(TCM) before I go and buy another one, and install. Please help .
new foreign user,
awkward
Old Mar 13, 2018 | 05:15 AM
georgeb944's Avatar
Probably not the TCM.
I would look at the ignition key removal lock cable adjustment. It is designed to force you into Park before you remove the ignition key... It also will not let you shift out of park until the ignition key is in the On position (and the brake pedal is pushed.)
Old Mar 13, 2018 | 06:58 AM
clancy's Avatar
Did you park on an incline and not secure it with the emergency prior to putting into park?
Old Mar 14, 2018 | 03:55 AM
Default Ignition key
i can get it out of park, into reverse but it will not go into any other gear, not even them manual “tap shift” I’m currently stuck in neutral and/or reverse now. And no I am not parked on any sort of incline that would put pressure on the parking brake system
Old Mar 14, 2018 | 03:58 AM
georgeb944's Avatar
Sounds like its time for a qualified mechanic to take a look...
HarrisonZ
Q7 MK 1 Discussion
9
Oct 9, 2015 02:16 AM
Audiallroadboy
Audi allroad
Dec 30, 2014 05:33 PM
ivonius4.2
Audi 100 / A6 (C4 Platform)
Feb 17, 2007 08:26 PM
SoCal Avanti
Aug 24, 2006 04:07 PM
thee007
Apr 8, 2005 03:17 PM
