Febi control arm creak when warm
So now that weather has warmed up, I'm getting the classic febi creak/groan when turning at slow speed. I sprayed all joints and bushings one at a time with soapy water, then WD, and then PBlaster and couldn't locate gremlin(s). Next, I injected grease into all ball joint boots, and I'm still getting the groan after a couple of days to let the grease work in. I'm thinking that perhaps the grease boot injection is not sufficient, and I need to install Zerk fittings to force the grease into the joint. Looks like I can add fittings to all joints except the lower arm with the solid aluminum ball joint end. Or is this a waste of time and I need to just replace the febi arms?
Anybody around who experienced this problem found the offending joints? Upper vs lower? Bushing vs ball joint? Other diagnosis tricks?
In my experience, zerk fittings are a waste of time. YMMV,
If you want to solve the problem quickly, replace all the parts at the same time. Not the cheap way, but expedient.
After researching this control arm noise issue further, it seems like most febi creaking noise issues with new arms are with bushings, unfortunately sometimes upper and sometimes lower.
During installation, I did torque the mounting bolts with a jack under the spindles to avoid stressing the bushings.
When the noise is present after driving for awhile, the noise and vibration seem to be coming from both sides. I though it might just be transmitted across the steering rack or body/subframe.
I'm going to try heating the inner bushing mounts up a bit with a heat gun one at a time to see if it's localized. I think I will try the lowers first. If nothing there, I will remove pinch bolt and pop balljoints to get easier movement of the upper arms, heat them up, and see if I can find the culprit. If more than one, I think I will replace all 6 non-febi arms with trw or lemforder. I have a hunch that more than one is creaking and probably the lowers.
I really don't want to replace arms one at a time with all the repetition involved, just looking for diagnostic approaches to avoid it.
