Accessing fan control module
Is there an easy way to do this? I've read that that if put into the service position it is easy, but can it be done without this being necessary? Anyone have experience doing this? I have never removed the bumper and put the front end into the service position. I'd like to avoid this step if I can.
Anyone have experience replacing the fan control control module that can offer me advice? It is a 2001A6 2.7 tiptronic.
thanks for any help offered.
You will have to remove the front bumper assembly completely and the headlight assembly to access the fan control module.
It's been awhile since I did one, but I seem to recall that there are nuts which attach the module to the bottom of the frame rail on the front left of the car. There are also several wire harnesses which snake through and around the fan assemblies. Take note of the routing to make sure that you don't end up with one of the fans slicing through the harness.
Thanks for the assistance.
Of course, YMMV, and it's your time, so do what you want.
Did not remove the headlight. I think that was mis-remember by georgeb944.
The wires were difficult to remove from the FCM probably because the plastic clips had never been removed in 18 years. Otherwise all went fine. Even the reassembly of the front end. The car started and the fans came on with the A/C. I won't know whether they go to high speed until we have another hot day and I am in Denver in traffic. I will report back when I know. I'll be taking the car to a much hotter environment soon. Wanted to get this done before the trip.
