2000 C5 A6 2.8 Intermittent Dash/Climate Control Failure
It is an intermittent issue. It happened a few times in the winter time (everything came back on within a few seconds.) But now it's all staying off.
For some odd reason, there's a short that kills my dash, climate control, headlights, turn signals, and 9v outlets. Car runs fine, radio works, windows work, alarm works, but for some reason everything else is dead. Like I said above, it's happened a few times before, but only when starting the car, and it would all come back within a few seconds. This made me think I had a faulty ignition switch, so I replaced that (and the airbag didn't go off in my face thank god.) Problem persisted.
I read something online about there being this battery control unit that diverts power when it senses your battery running low on juice just so you can still start the car. I replaced the battery, and after driving it for a few minutes everything came back on! So here I am thinking I fixed everything with a simple battery. Then today (about 2 weeks after replacing the battery) I was getting off the freeway and decided to turn off the AC. As soon as I pressed the off button, the dash went dead, and I couldn't turn the AC on again. Same symptoms as before.
I called up a buddy with a voltmeter and had him test my battery/alternator/grounds. Everything checks out. So now I'm looking into a control unit. ECU? That battery control unit? I'm completely stumped and have no idea which direction to move in now. I'm hoping someone can lend some knowledge out my way!!!!
I have not performed a load test on the battery. I'll try and give that a go.
The car has 154k miles, and I do have all the service records believe it or not.
Since both the dash and climate control go out at the same time, is there a control module somewhere that might be disrupting the circuit?
Does anyone know where I can find a diagram that lays out wiring for this particular part?
Any help at this point would be extremely useful.
It's always the easy solutions that have us scratching our heads, right?
Either way, she's back on the road!!!
