Clutch slipping in 1st gear.
Old Oct 10, 2005 | 10:07 AM
HaVoC's Avatar
New Member
Default Clutch slipping in 1st gear.
The clutch on my 99.5 Quattro constantly has trouble gripping in 1st gear. However the clutch never slips in higher gears (3rd, 4th, 5th). This problem is the worst when starting from a stop on an incline. Sometimes I will have to pump the clutch pedal to get it to finally catch in 1st gear. Anyone have experience with this problem?
In the search I read about clutches slipping in higher gears, but I couldn't find any good info on slipping in 1st gear.
Old Oct 10, 2005 | 10:10 AM
CURSH's Avatar
Default Sounds like your clutch doesnt like traction.
maybe you should get a new one.
Old Oct 10, 2005 | 10:13 AM
HaVoC's Avatar
New Member
Default It's been doing this for ~ 5K miles
and it has slowly gotten worse, but I can't get the clutch to slip in higher gears if I wanted to. Could one component of the clutch be worn out? (Maybe the pressure plate?)
Old Oct 10, 2005 | 10:27 AM
JAFO's Avatar
Default does it get worse the longer you drive?....
i had this it was the front main seal on the trans. dropping lube oil on the clutch.
Old Oct 10, 2005 | 10:28 AM
HaVoC's Avatar
New Member
No, if anything it might get better
Old Oct 10, 2005 | 10:30 AM
JAFO's Avatar
time for a new clutch.
Old Oct 10, 2005 | 12:10 PM
Speedy72t's Avatar
Default I've always found it to show up in top gear to begin with.
that's kinda strange that it only slips in first. You could have my problem. Mine starts grabbing in first with the pedal to the floor. I figured the master cylinder was going bad but that doesn't appear to be the case. I'm beginning to think something with the throwout bearing is going south.
Old Oct 10, 2005 | 01:45 PM
HaVoC's Avatar
New Member
Yeah it is weird. I couldn't find any similar problems in search.
 Pouria Savadkouei
 Michael S. Palmer
jmerber
Dec 22, 2016 11:09 AM
joesc
Oct 22, 2003 07:12 AM
Mark.core
Oct 29, 2002 07:15 AM
T-28-Quattro de VT
Aug 27, 2001 03:54 PM
BillG
Jan 24, 2000 09:17 AM
