A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Changed battery, now no crank no start. 2005 A6 3.2
Old Jan 22, 2024 | 04:50 AM
Deidrik's Avatar
Default Changed battery, now no crank no start. 2005 A6 3.2
Had a bad battery that I replaced, now I'm getting no crank. After changing the battery and it not starting (changed it in the auto parts parking lot) I reinstalled the old battery and tried starting using jump pack but still didn't work. Recoded the battery in VCDS and that didn't do anything but shut MMI off for some reason. (Changed the part number saved in 61 - battery management after that which brought back MMI somehow)
This car has had some... modification prior to me owning it. Starter relay 1 has a jumper wire already installed across it, I'm guessing that gets the signal from the PN selector since that has been a code in vcds since I got the car. When I turn the key I can feel starter relay 2 engage. Multimeter readings across starter relay 1 go from 0v at rest to 11.8v when cranking the key.
Could there have been any weird VCDS changes that allowed the car to start that got cleared when I unhooked the battery? Could the starter have just happened to die at the same time as I changed the battery? Any thoughts guys?
Old Jan 23, 2024 | 07:36 PM
Deidrik's Avatar
Update - before I started throwing parts at the problem, I decided to cover the easy stuff. Checked every fuse but still no luck. I remembered when changing the battery the ground from the battery post to the battery control box got loose so I just tightened it back down so I pulled that connection apart, cleaned the connector and post with some sandpaper, and now it starts again - shut it off and restarted it 3 times. I guess I was over-thinking it.
gabb0005
A6 (C7 Platform) Discussion
13
Dec 6, 2023 03:41 PM
groovysteve
Mar 29, 2021 08:05 AM
flippity_01
A4 (B7 Platform) Discussion
Nov 16, 2018 11:58 AM
jloktalGst
May 30, 2018 03:56 PM
Supra James
Dec 14, 2010 01:53 AM
