G28 / Crankshaft Position Sensor
Old Sep 13, 2024 | 05:55 PM
MainelyA8's Avatar
Default G28 / Crankshaft Position Sensor
Good news is that it has been successfully replaced, and waited until 200k miles to suddenly die. Bad news is that I somehow managed to break this cover plate removing the (stripped) middle bolt. I have no idea how that happened. Probably not going to replace this since I barely drive this car anymore, but I'll check to see if I can find one first.
Old Sep 16, 2024 | 05:52 PM
AEightSilver's Avatar
If that is aluminum, maybe a machine shop can do a weld repair? Its just a shield.
Old Mar 5, 2026 | 07:36 PM
maxandtara's Avatar
Just completed mine today.
What nobody talks about is that this is a real PITA job if you want it done properly.
There are 3 layers of thin Heat Shields and the hefty splash shield .
1. First layer covers the harness of the 3 connectors beside the "crankshaft position sensor".
2. The 2nd and 3rd layer protects the "crankshaft position sensor"
I am assuming here that the audi engineers decided that it is necessary to have the wire harness and crankshaft position sensor wiring "separated" in this area.
Putting everything back is the PITA as part.
If it is possible to glue/tape everything together, you can attach everything in one shot.
I did it the hard way, installed one layer at a time.
shield 1 - install one bolt at one end.
shield 2 - Install bolt at the opposite end and remove first bolt that holds shield 1
( i hope you get the picture)
maccarjm
Audi A3 / S3 / RS 3
Mar 16, 2023 12:02 AM
syncopated
Q5/SQ5 MKI (8R) Discussion
Jun 5, 2018 09:24 AM
aaron843
Mar 16, 2014 06:37 AM
nohcs
Mar 9, 2011 03:27 PM
EricPA
Feb 7, 2005 07:02 AM
